Project User with Perspective IdP can change own password?
Hello!
I would like to know if perspective project users with perspective IdP can change their own password somehow or just the administrator can do it?
Thanks.
What are you using to edit passwords, this exchange resource perhaps?
That's pretty broad. If you are using an external IdP, no chance. If you are using Ignition's IdP with an internal user source, then yes. Other combinations, like Active Directory user sources, generally not.
I using internal IdP.
So I guess you can´t edit passwords from the gateway. Just using the Perspective User Management resource?
Based on what you state you are using, you can use both. But you normally wouldn't want typical users in the gateway, would you?
I don't think the exchange resource has any security baked in, meaning anyone can edit users. So, it's up to you to control who can access.
Yes, it would be enough to edit the passwords from the gateway by the administrator, but right now I think I can´t do this.
Why do you think you can't, have you tried?
Hello @jlandwerlen,
On the trial version I´m using until we aply the license I can´t edit the passwords of the users once they are created.
Cheers.
Did you?
Oh, didn´t!, thanks and sorry.
The trial license is fully functional. There are no disabled features.
You should have led with this post.
