Project using wrong tagprovider
I have several tag provider modules installed on the gateway. I have a project set to use one tag provider but when trying to submit an action from the client I get an error that says “cannot run “providerName.method”, no RPC handler”. I do have an RPC handler for the specific method. Below is the call stack.
File “event:actionPerformed”, line 1, in
File “module:tagmgmt”, line 176, in applyValuesToTagDefTable
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:312)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:286)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:243)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvoke(GatewayInterface.java:761)
at com.bloomenergy.hmi.client.BEModuleRPCProxy.invoke(BEModuleRPCProxy.java:19)
at com.bloomenergy.hmi.client.BEModuleRPCProxy.loadTagdef(BEModuleRPCProxy.java:29)
at com.bloomenergy.hmi.client.BEModuleRPCProxy.loadTagdef(BEModuleRPCProxy.java:24)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run “betagprovider_2.0.0.11.loadTagdef”, no RPC handler.
at org.python.core.Py.JavaError(Py.java:481)
at org.python.core.Py.JavaError(Py.java:474)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:455)
at org.python.core.PyObject.__call__(PyObject.java:371)
at org.python.core.PyObject.__call__(PyObject.java:375)
at org.python.pycode._pyx365.applyValuesToTagDefTable$14(<module:tagmgmt>:179)
at org.python.pycode._pyx365.call_function(<module:tagmgmt>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.pycode._pyx364.f$0(<event:actionPerformed>:1)
at org.python.pycode._pyx364.call_function(<event:actionPerformed>)
at org.python.core.Py.runCode(Py.java:1261)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy15.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run “betagprovider_2.0.0.11.loadTagdef”, no RPC handler.
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 54 more
Caused by: java.lang.IllegalStateException: Cannot run “betagprovider_2.0.0.11.loadTagdef”, no RPC handler.
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:76)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:398)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:724)
Ignition v7.5.2 (b1146)
Java: Oracle Corporation 1.7.0_25
The RPC is executed via “moduleId.functionName”. Does your 2.0.0.11 module have a module id of “betagprovider_2.0.0.11”? I’m guessing that must be slightly off. Or, your function name isn’t exactly correct… in the stack is says “loadTagdef”, with a lower cased “d”. Is it actually “loadTagDef”? These are all case sensitive.
Good luck,
