Can we Only Assigned specific project to specific TagProvider? .. I would like Only Project(A) able to access to TagProvider(A) only from designers .
Tag Providers have Tag Read Permissions built into their default settings on the Gateway. That would be the simplest way to limit who can write, read or edit tags. Although it would not be based around project security it would use Gateway Identity Provider Security Levels.
You cannot meaningfully prevent someone who has access to the Designer from accessing other gateway resources.
