I “Restored” the gateway with a .gwbk from my dev server after adding some tags and scripts and now the gateway will not start.
My Dev Server is 8.1.9 since I got no error message when restoring I assume my Production install is 8.1.9 as well. (where Can I check this if I can’t get the gateway to start?)
ETA: Ok this time around it actually started but it took 20 minutes. That is insane. It
I updated the log below.
yeah, it is working now but that’s hardly acceptable for it to take 20 minutes to start.
WARN | wrapper | 2021/09/15 02:46:21 | The “wrapper.java.additional.auto_bits.macosx” property was redefined on line #68 of configuration file: C:\Program Files\Inductive Automation\Ignition\data\ignition.conf
WARN | wrapper | 2021/09/15 02:46:21 | Old Value wrapper.java.additional.auto_bits.macosx=FALSE
WARN | wrapper | 2021/09/15 02:46:21 | New Value wrapper.java.additional.auto_bits.macosx=FALSE
STATUS | wrapper | 2021/09/15 02:46:21 | → Wrapper Started as Service
STATUS | wrapper | 2021/09/15 02:46:21 | Java Service Wrapper Standard Edition 64-bit 3.5.42
STATUS | wrapper | 2021/09/15 02:46:21 | Copyright (C) 1999-2020 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2021/09/15 02:46:21 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2021/09/15 02:46:21 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2021/09/15 02:46:22 | Launching a JVM…
INFO | jvm 1 | 2021/09/15 02:46:23 | WrapperManager: Initializing…
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:24,836 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:25,145 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:25,160 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:25,177 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:25,263 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2021/09/15 02:46:25 | 02:46:25,294 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,172 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@18c19dae - Driver name=SQLite JDBC
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,172 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@18c19dae - Driver version=3.23.1
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,172 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@18c19dae - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,193 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,200 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,200 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,201 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,202 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,205 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,209 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,210 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,210 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,211 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,212 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,212 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,213 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,213 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,218 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@60b7487d - Registering current configuration as safe fallback point
INFO | jvm 1 | 2021/09/15 02:46:26 | 02:46:26,344 |-INFO in ch.qos.logback.classic.jul.LevelChangePropagator@6ac9783d - Propagating INFO level on Logger[ROOT] onto the JUL framework
INFO | jvm 1 | 2021/09/15 02:46:26 | W [WebResourceManagerImpl ] [06:46:26]: Unable to read “gateway.metroKeystoreAlias” gateway.xml property. Assuming metro keystore alias is: metro-key
INFO | jvm 1 | 2021/09/15 02:46:27 | I [o.e.j.u.log ] [06:46:27]: Logging initialized @4874ms to org.eclipse.jetty.util.log.Slf4jLog
INFO | jvm 1 | 2021/09/15 02:46:27 | I [g.WebServerManager ] [06:46:27]: Starting setup
INFO | jvm 1 | 2021/09/15 02:46:27 | I [g.WebServerManager ] [06:46:27]: Setup complete
INFO | jvm 1 | 2021/09/15 02:46:28 | I [g.WebServerManager ] [06:46:28]: Starting up
INFO | jvm 1 | 2021/09/15 02:46:28 | I [C.SecureRandomProvider ] [06:46:28]: Secure random seed generated in 3ms
INFO | jvm 1 | 2021/09/15 02:46:28 | I [o.e.j.s.Server ] [06:46:28]: jetty-9.4.24.v20191120; built: 2019-11-20T21:37:49.771Z; git: 363d5f2df3a8a28de40604320230664b9c793c16; jvm 11.0.11+9-LTS
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.e.j.s.session ] [06:46:29]: DefaultSessionIdManager workerName=node0
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.e.j.s.session ] [06:46:29]: No SessionScavenger set, using defaults
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.e.j.s.session ] [06:46:29]: node0 Scavenging every 660000ms
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.Application ] [06:46:29]: [WicketFilter] init: Wicket core library initializer
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=IBehaviorListener, method=public abstract void org.apache.wicket.behavior.IBehaviorListener.onRequest()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=IFormSubmitListener, method=public abstract void org.apache.wicket.markup.html.form.IFormSubmitListener.onFormSubmitted()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=ILinkListener, method=public abstract void org.apache.wicket.markup.html.link.ILinkListener.onLinkClicked()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=IOnChangeListener, method=public abstract void org.apache.wicket.markup.html.form.IOnChangeListener.onSelectionChanged()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=IRedirectListener, method=public abstract void org.apache.wicket.IRedirectListener.onRedirect()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.RequestListenerInterface] [06:46:29]: registered listener interface [RequestListenerInterface name=IResourceListener, method=public abstract void org.apache.wicket.IResourceListener.onResourceRequested()]
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.Application ] [06:46:29]: [WicketFilter] init: Wicket extensions initializer
INFO | jvm 1 | 2021/09/15 02:46:29 | I [IgnitionGateway ] [06:46:29]: Ignition[state=STOPPED] ContextState = STARTING
INFO | jvm 1 | 2021/09/15 02:46:29 | I [o.a.w.p.h.WebApplication ] [06:46:29]: [WicketFilter] Started Wicket version 6.30.0 in DEPLOYMENT mode
INFO | jvm 1 | 2021/09/15 02:46:29 | I [IgnitionGateway ] [06:46:29]: Starting Ignition 8.1.9 (b2021080617)
INFO | jvm 1 | 2021/09/15 02:46:29 | I [IgnitionGateway ] [06:46:29]: Reloading JDBC classloader.
INFO | jvm 1 | 2021/09/15 02:46:30 | I [R.S.S.InternalDb ] [06:46:30]: Internal db synchronizer disk cache initialized. State id=0354f2e9-1139-45e5-bc3e-2b7fb3e449ed
INFO | jvm 1 | 2021/09/15 02:46:30 | I [R.StateMonitoring ] [06:46:30]: Redundancy state changed: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO | jvm 1 | 2021/09/15 02:46:30 | I [o.e.j.s.h.ContextHandler ] [06:46:30]: Started c.i.c.MainWebAppContext@75c0a695{Ignition,/,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,AVAILABLE}
INFO | jvm 1 | 2021/09/15 02:46:30 | I [o.e.j.s.AbstractConnector ] [06:46:30]: Started ServerConnector@4d112243{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2021/09/15 02:46:31 | I [g.InternalDatabaseManager ] [06:46:31]: Starting up…
INFO | jvm 1 | 2021/09/15 02:46:31 | I [P.InternalDatabase ] [06:46:31]: Looking for existing internal database “config.idb”…
INFO | jvm 1 | 2021/09/15 02:46:31 | I [P.InternalDatabase ] [06:46:31]: … found existing.
INFO | jvm 1 | 2021/09/15 02:46:31 | I [P.InternalDatabase ] [06:46:31]: internal database “config.idb” started up successfully.
INFO | jvm 1 | 2021/09/15 02:46:31 | I [P.InternalDatabase ] [06:46:31]: Registering autobackup task [owner=Internal DB Autobackup, name=internal database “config.idb”]
INFO | jvm 1 | 2021/09/15 02:46:31 | WARNING: An illegal reflective access operation has occurred
INFO | jvm 1 | 2021/09/15 02:46:31 | WARNING: Illegal reflective access by com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl (file:/C:/Program%20Files/Inductive%20Automation/Ignition/lib/core/gateway/gateway-8.1.9.jar) to field java.lang.ClassLoader.usr_paths
INFO | jvm 1 | 2021/09/15 02:46:31 | WARNING: Please consider reporting this to the maintainers of com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl
INFO | jvm 1 | 2021/09/15 02:46:31 | WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
INFO | jvm 1 | 2021/09/15 02:46:31 | WARNING: All illegal access operations will be denied in a future release
INFO | jvm 1 | 2021/09/15 02:46:32 | I [o.e.j.s.AbstractConnector ] [06:46:31]: Started ServerConnector@1cacafe2{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2021/09/15 02:46:32 | I [o.e.j.s.Server ] [06:46:31]: Started @9438ms
INFO | jvm 1 | 2021/09/15 02:46:32 | I [SystemInfo ] [06:46:32]: os.name=“windows 10”, os.arch=“amd64”.
INFO | jvm 1 | 2021/09/15 02:46:32 | I [SystemInfo ] [06:46:32]: Validating native library “ignition64”…
INFO | jvm 1 | 2021/09/15 02:46:32 | I [SystemInfo ] [06:46:32]: Validated ignition64 (ignition64.dll)
INFO | jvm 1 | 2021/09/15 02:46:32 | I [SystemInfo ] [06:46:32]: Loading native library “ignition64”…
INFO | jvm 1 | 2021/09/15 02:46:32 | I [SystemInfo ] [06:46:32]: Native library load complete
INFO | jvm 1 | 2021/09/15 02:46:32 | I [g.ModuleManager ] [06:46:32]: Loading modules…
INFO | jvm 1 | 2021/09/15 02:46:36 | I [A.Notification ] [06:46:36]: Alert notification system created.
INFO | jvm 1 | 2021/09/15 02:46:37 | I [g.PersistentRecordSecurityLevelConfigService] [06:46:37]: Set up in 23 ms
INFO | jvm 1 | 2021/09/15 02:46:37 | I [g.PersistentRecordIdpAdapterConfigService] [06:46:37]: Set up in 46 ms
INFO | jvm 1 | 2021/09/15 02:46:37 | I [g.PersistentRecordIdpAdapterMetricsService] [06:46:37]: Set up in 41 ms
INFO | jvm 1 | 2021/09/15 02:46:37 | I [IgnitionGateway ] [06:46:37]: System properties exist in IDB. Checking if system IdP is set…
INFO | jvm 1 | 2021/09/15 02:46:38 | I [g.InternalDatabaseRememberedSubjects] [06:46:37]: Set up in 36 ms
INFO | jvm 1 | 2021/09/15 02:46:38 | I [g.OIDCProviderManager ] [06:46:37]: Set up in 37 ms
INFO | jvm 1 | 2021/09/15 02:46:39 | I [T.LegacyTagConverter ] [06:46:39]: Converting legacy tag provider ‘System’
INFO | jvm 1 | 2021/09/15 02:46:40 | I [m.M.Routing ] [06:46:40]: Setting max proxy route depth = 1
INFO | jvm 1 | 2021/09/15 02:46:40 | I [c.i.i.g.p.r.ProjectRecordConverter] [06:46:40]: Conversion finished. Elapsed time: 75 ms
INFO | jvm 1 | 2021/09/15 02:46:46 | W [g.LicenseManager ] [06:46:46]: Could not read license from HASP key. HASP login() failed. Last error = 14.
INFO | jvm 1 | 2021/09/15 02:46:48 | I [g.ModuleManager ] [06:46:48]: Setting up modules
INFO | jvm 1 | 2021/09/15 02:46:48 | I [c.i.i.g.o.KeyStoreManager ] [06:46:48]: Loading KeyStore at C:\Program Files\Inductive Automation\Ignition\data\opcua\client\security\certificates.pfx
INFO | jvm 1 | 2021/09/15 02:46:49 | I [c.i.i.g.o.KeyStoreManager ] [06:46:49]: Loading KeyStore at C:\Program Files\Inductive Automation\Ignition\data\opcua\server\security\certificates.pfx
INFO | jvm 1 | 2021/09/15 02:46:50 | I [o.e.m.o.s.s.OpcUaServer ] [06:46:50]: Eclipse Milo OPC UA Stack version: 0.6.1
INFO | jvm 1 | 2021/09/15 02:46:50 | I [o.e.m.o.s.s.OpcUaServer ] [06:46:50]: Eclipse Milo OPC UA Server SDK version: 0.6.1
INFO | jvm 1 | 2021/09/15 02:46:55 | I [o.e.m.o.s.s.n.OpcUaNamespace ] [06:46:55]: Loaded 2004 nodes in 2691ms.
INFO | jvm 1 | 2021/09/15 02:46:55 | I [QuickStart ] [06:46:55]: Skipped Quick Start feature; missing required module(s): ‘Reporting, Tag Historian, Perspective’
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.PersistentRecordSecurityLevelConfigService] [06:46:58]: Started up in 0 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.SecurityLevelManager ] [06:46:58]: Started up in 4 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.PersistentRecordIdpAdapterConfigService] [06:46:58]: Started up in 59 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.PersistentRecordIdpAdapterMetricsService] [06:46:58]: Started up in 0 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.IdpAdapterManager ] [06:46:58]: Started up in 1 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.InternalDatabaseRememberedSubjects] [06:46:58]: Started up in 15 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [g.OIDCProviderManager ] [06:46:58]: Started up in 18 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [t.m.provider ] [06:46:58]: Tag provider initialized. Starting to load tags… provider=System
INFO | jvm 1 | 2021/09/15 02:46:58 | I [t.m.provider ] [06:46:58]: Complete tag loading in 294 ms
INFO | jvm 1 | 2021/09/15 02:46:58 | I [t.manager ] [06:46:58]: Instantiating provider ‘default’ of type ‘STANDARD’
INFO | jvm 1 | 2021/09/15 02:46:59 | I [t.m.provider ] [06:46:59]: Tag provider initialized. Starting to load tags… provider=default
INFO | jvm 1 | 2021/09/15 02:47:00 | I [t.e.dispatcher ] [06:47:00]: ProjectManager not yet running, rescheduling for +2 seconds tag=Trigger Reading
INFO | jvm 1 | 2021/09/15 02:48:00 | I [t.e.dispatcher ] [06:48:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:49:00 | I [t.e.dispatcher ] [06:49:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:50:00 | I [t.e.dispatcher ] [06:50:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:51:00 | I [t.e.dispatcher ] [06:51:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:52:01 | I [t.e.dispatcher ] [06:52:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:53:00 | I [t.e.dispatcher ] [06:53:00]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:54:01 | I [t.e.dispatcher ] [06:54:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:55:01 | I [t.e.dispatcher ] [06:55:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:56:01 | I [t.e.dispatcher ] [06:56:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:57:01 | I [t.e.dispatcher ] [06:57:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:58:01 | I [t.e.dispatcher ] [06:58:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 02:59:01 | I [t.e.dispatcher ] [06:59:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:00:01 | I [t.e.dispatcher ] [07:00:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:01:01 | I [t.e.dispatcher ] [07:01:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:02:01 | I [t.e.dispatcher ] [07:02:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:03:01 | I [t.e.dispatcher ] [07:03:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:04:01 | I [t.e.dispatcher ] [07:04:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:05:01 | I [t.e.dispatcher ] [07:05:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:06:01 | I [t.e.dispatcher ] [07:06:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:07:01 | I [t.e.dispatcher ] [07:07:01]: ProjectManager not yet running, rescheduling for +2 seconds
INFO | jvm 1 | 2021/09/15 03:07:13 | I [t.m.provider ] [07:07:13]: Complete tag loading in 20 minutes, 14 seconds
INFO | jvm 1 | 2021/09/15 03:07:13 | I [i.UserSourceManager ] [07:07:13]: Starting up…
INFO | jvm 1 | 2021/09/15 03:07:13 | I [AuditManager ] [07:07:13]: AuditManager starting up…
INFO | jvm 1 | 2021/09/15 03:07:13 | I [A.S.StorageManager ] [07:07:13]: Starting up…
INFO | jvm 1 | 2021/09/15 03:07:13 | I [A.N.NotificationManager ] [07:07:13]: Starting up…
INFO | jvm 1 | 2021/09/15 03:07:14 | W [t.h.query ] [07:07:14]: Tag history provider record exists for unknown provider type ‘datasource’
INFO | jvm 1 | 2021/09/15 03:07:14 | I [S.S.HsqlDataStore ] [07:07:14]: Looking for existing store and forward datacache “Redacted”… store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:14 | I [S.S.HsqlDataStore ] [07:07:14]: … no files found, will create. store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:14 | I [S.S.HsqlDataStore ] [07:07:14]: Creating new store and forward datacache “Redacted”. store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: Checkpoint start store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: checkpointClose start store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: checkpointClose synched store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: checkpointClose script done store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: checkpointClose end store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:15 | I [h.d.H.ENGINE ] [07:07:15]: Checkpoint end - txts: 1 store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [h.d.H.ENGINE ] [07:07:15]: checkpointClose end store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [h.d.H.ENGINE ] [07:07:15]: Checkpoint end - txts: 9 store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [S.S.HsqlDataStore ] [07:07:15]: store and forward datacache “Redacted” started up successfully. store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [h.d.H.ENGINE ] [07:07:16]: dataFileCache open start store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [h.d.H.ENGINE ] [07:07:16]: dataFileCache open end store-forward-name=Redacted
INFO | jvm 1 | 2021/09/15 03:07:16 | I [S.S.StandardDatasourceSFEngine] [07:07:16]: History sink ‘Redacted’ started successfully.
INFO | jvm 1 | 2021/09/15 03:07:16 | I [ImageManager ] [07:07:16]: Starting up…
INFO | jvm 1 | 2021/09/15 03:07:16 | I [Project ] [07:07:16]: Starting project: x
