I have been trying to modify or delete the projects. Because I, cannot able to see delete/details/export options in the "More" actions for the selected project.
The only Copy option is enabled. Can anyone help with the suggestion to resolve this issue? For reference, check the screenshot attached here.
For your information, I tried to uninstall the ignition gateway and designer a couple of times and reinstalled them again both times. Still, this issue persistently shooting up.
The 'More' dropdown should have a white background. Have you got a dark theme applied to your browser somehow.
I think we'll need your Ignition version, OS and browser brand.
Hi Transistor,
I haven't chosen any dark theme in my browser. However, I tried installing ignition gateways with versions 8.1.22, 8.1.23 & 8.1.28. None of the gateway versions replaced this issue.
OS installed on the laptop is Windows 11 Pro, and the browser is google chrome.
Disable all your browser extensions, or try the gateway webpage in an incognito window with no extensions loaded. Or a different browser.
Hi PGriffith,
Yes, it worked after disabling all the extension in browser and reloaded the page. I can able to have a control on projects.
Thank you for the support
