propertyChange is not being triggered
hello everyone,
I have an "image" component where I want it to be shown when some values change, but it is not being executed.
# Read custom property values
sp_p = event.source.SP_P
active_power = event.source.Active_Power
timer_value = event.source.timer
# Calculate the condition
#condition_met = (abs((sp_p - active_power) / active_power) * 100 > 115) and (sp_p_2 > 0.25)
condition_met = sp_p > active_power
if condition_met:
    timer_value += 1
else:
    timer_value = 0
# Updating the timer
event.source.timer = timer_value
what am I doing wrong?
You aren't checking the property name. You won't make much progress until you indent everything and put if event.propertyName == 'something': ahead of it. In Vision, property change scripts run for every property that fires changes. You must filter for the properties of interest.
Thanks, Phil. Initially, it worked for me by adding the condition:
and that 'something' would be a custom property. It ended up like this:
active_power = event.source.active_power
counter = event.source.counter
if event.propertyName == "counter":
    if sp_p >= active_power:
        timer_value += 1
    else:
        timer_value = 0
the counter is incrementing every second, I did this from the gateway event script.
What I wanted was for the component to be visible only if the condition is met for more than 10 seconds; otherwise, it should not be shown. By doing this and adding a visible expression, it worked:
{[PROJECT]System/TEST/Temp_condition_Timer/Condition_Timer_2_2_1} >= 10
thanks again.
Note that even your other property accesses should be inside the if, for best performance of all the events that you don't process.
