The error PublishRequestPump is appearing a lot in our log can you tell me what it means and how do we prevent it. I have pasted a sample below.
Time Logger Message
(I) 09:03:05 ENGINE Initiating backup of instance ‘settings’
(I) 09:03:05 ENGINE checkpointClose end
(I) 09:03:05 ENGINE dataFileCache commit start
(I) 09:03:05 ENGINE checkpointClose start
(I) 09:03:05 LocalDBManagerImpl Creating auto-backup of internal database “settings”…
(I) 08:41:05 LocalDBManagerImpl Created auto-backup of internal database “settings” in 3 seconds
(I) 08:41:05 ENGINE Successfully backed up instance ‘settings’ to ‘C:\Program Files\Inductive Automation\Ignition\data\db\autobackup\db_20130702_084101.tar.gz’
(I) 08:41:01 ENGINE Initiating backup of instance ‘settings’
(I) 08:41:01 ENGINE checkpointClose end
(I) 08:41:01 ENGINE dataFileCache commit start
(I) 08:41:01 ENGINE checkpointClose start
(I) 08:41:01 LocalDBManagerImpl Creating auto-backup of internal database “settings”…
08:37:59 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=52268]’.
StatusCode[Severity=Bad, Subcode=Bad_Timeout]: Request timed out after 62500ms.
at com.inductiveautomation.xopc.client.stack.TCPClientChannel$UaRequestTimeout.run(TCPClientChannel.java:419)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
(I) 08:26:04 Projects$ProjectChangeMonitor Starting up client project monitor. project=SCADA, uuid=246d7163-5565-0f51-0c45-b7c7cdba9b2e, editCount=5934, scope=4, version=Published
08:09:59 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=52092]’.
07:11:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51742]’.
(I) 07:09:46 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20960.
07:09:46 UaSubscription[Scanclass ‘Default[default]’] Previous SequenceNumber=20961, received SequenceNumber=20959; republishing.
07:09:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51731]’.
07:09:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51730]’.
07:09:14 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51729]’.
(I) 07:05:45 Projects$ProjectChangeMonitor Starting up client project monitor. project=SCADA, uuid=246d7163-5565-0f51-0c45-b7c7cdba9b2e, editCount=5934, scope=4, version=Published
06:59:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51673]’.
06:59:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51672]’.
06:59:14 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51671]’.
(I) 06:43:46 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20892.
(I) 06:43:46 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20891.
06:43:46 UaSubscription[Scanclass ‘Default[default]’] Previous SequenceNumber=20893, received SequenceNumber=20890; republishing.
06:43:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51583]’.
06:43:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51582]’.
06:43:09 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51581]’.
06:42:59 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51580]’.
06:35:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51539]’.
(I) 06:34:01 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20871.
06:34:01 UaSubscription[Scanclass ‘Default[default]’] Previous SequenceNumber=20872, received SequenceNumber=20870; republishing.
06:33:49 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51531]’.
06:33:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51530]’.
06:33:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51529]’.
06:33:14 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51528]’.
06:25:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51487]’.
06:25:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51486]’.
06:25:14 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51485]’.
06:23:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51477]’.
06:23:19 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51476]’.
06:23:14 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51475]’.
(I) 06:09:55 Projects$ProjectChangeMonitor Starting up client project monitor. project=SCADA, uuid=246d7163-5565-0f51-0c45-b7c7cdba9b2e, editCount=5934, scope=4, version=Published
(I) 06:07:46 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20816.
(I) 06:07:46 UaSubscription[Scanclass ‘Default[default]’] Calling Republish for SequenceNumber=20815.
06:07:46 UaSubscription[Scanclass ‘Default[default]’] Previous SequenceNumber=20817, received SequenceNumber=20814; republishing.
06:07:34 PublishRequestPump Received failure notification for request ‘[PublishRequest requestHandle=51390]’.
Ignition by Inductive Automation. Copyright © 2003-2013. All rights reserved. | view license
