Hi all,
I’m working on an architectural proposal for a client that includes Ignition. Traditionally, I’d include a “Test” environment where changes can be tested before they are published in to the “Production” environment. These changes are usually migrated from Test to Production through some kind of publishing process. Does Ignition facilitate this kind of workflow? Any suggestions to keep manual edits out of Production?
I should also note that I’m using UDTs, so using the SQL Tag Provider is not an option.
Thanks in advance!
Davin
