Hello,
since wie upgraded our Ignition live gateway from 8.1.50 to 8.3.3 we frequently run into issues with the Publishing manager (Republish service failure, sequenceNumber=xxxxxx) and OpcUaSubscriptionManager (
onNotificationDataLost(): ResendData failure: UaServiceFaultException: status=Bad_ServiceUnsupported, message=The server does not support the requested service.
and
onNotificationDataLost(): SetMonitoringMode failure
The subscription targets a kepware server. The big problem is, after this messages all opc tags change from good quality to uncertain last known value and we react to a quality change.
Anyone experienced similar behavior?
The issue is basicly easy fixed by restarting the opc Tag (or the folder the xk tags are inside), but this needs to be done manually... Any ideas how to prevent this?
Thanks for all help
