Pulling custom property from parent component
I'm using Vision to create a screen showing several pieces of data from different tags of the same UDT type. I grouped a bunch of labels together. I tried using Indirect Tags, but that is hardcoding the Group name into the tag. All this is doing is changing the place I have to change the reference on every label.
Direct tag:
Path: [tags_Testcell]RTDs/TE1/Value/Alarms/Alarm_High.IsActive
Indirect tag:
Path: [tags_Testcell]RTDs/{1}/Value/Alarms/Warning_High.IsActive
Ref: Root Container.Group RTD 1.ID
Instead of changing the TE value in the direct path, I have to change the Group RTD number in the indirect reference. I'd like the reference to point to the parent (which is the group), so I would change the ID value for each group and all the labels in that group would automatically look to the new tag.
Tip: I think your question title should read "... from parent tag". Tags aren't generally referred to as "components". Components are the elements which make up a Vision window or a Perspective view.
Welcome to the forum.
How are you putting the value in to the Group RTD 1.ID property?
How have you set up the labels in the group to get their values?
How are the UDTs named and does that corespond to the ID?
