Pump animationDirection
I'm using a pump symbol in Ignition Perspective, and I can adjust its animationSpeed property successfully. However, I also need to change the rotation direction of the pump's fan. By default, it rotates clockwise, but I want it to rotate anti-clockwise.
I've tried modifying the transform and animationDirection properties, but they don’t seem to have any effect.
Is there a proper way to reverse the rotation direction of the pump animation?
Thanks in advance for your help!
May I ask what benefit or value is added by the pump rotation being a specific direction? If you want to convey the direction to the operator, might I suggest a label that states the direction.
Thanks for the help! I was able to fix the issue by using the transform property — I flipped the pump horizontally, and that reversed the rotation direction as needed.
Appreciate the guidance!
