Push Button On Template with Indirect Addressing Not Turning on in the PLC
Hi Experts,
I am hoping someone can help me. I have soured the forum, but I am unable to anything to help with my problem.
The site is using Ignition V7.9 connected to a AB CompactLogix 1769-L33ER at V32.
I have created a "popup" page with multiple parameters using indirect Tag Addressing which works perfectly. Depending on the button to call the popup, determines which parameter group is displayed.
I am now trying to add an "Auto" & "Off" Push Buttons onto the popup.
I have tried using a "1 Shot Button" and applied the indirect addressing, the same as the other parameters with no success. Is this a known issue with Ignition V7.9?
How do I apply the "Page Root Container PoolNumber" Variable as a substitute for POOL_1A?
event.source.parent.PoolNumber
value = 1
system.tag.write('Stage2_ValvePit/Pool_1A/TempSP/Auto/AutoPB', value)
Thank You
Woolie
Did you make the binding Bidirectional? If not then you aren't writing the new value anywhere.
tagName = 'Stage2_ValvePit/%s/TempSP/Auto/AutoPB' % event.source.parent.PoolNumber
value = 1
system.tag.write(tagName, value)
Thanks Ryan,
That piece of code is exactly what I was trying to write.
I can cope sort of with Cicode (Citect) and some other languages, but Python / Json seems to get me confused.
Again Thanks for your prompt reply and the solution.
Woolie
My example is technically worse, its Python with Java's string formatting syntax. Python uses {} in conjunction with .format(), Java uses %. Jython lets you do that. :person_shrugging:
https://docs.python.org/2.7/library/string.html#format-string-syntax
If you watch any of the basic python tutorials out there that will get you 80-90% of the way. Syntax is the main thing to nail down, after that it's learning to handle Ignition's specific data types and methods.
Edit: Fixed link to point to python 2.7
Thanks for the links. Looks like there is more learning to be done over the weekend. Good thing I don't have a life!
Thanks again
Woolie
Careful, 7.9 is still Python 2.5 which I don’t believe supports the .format() on strings. Pretty sure you still need to use the old style format parameters as you have shown in the script.
You really should not point at Python3 documentation for Ignition purposes. This is better:
Ignore the warning banner, it isn't applicable to Jython.
Thanks to you both, Irose & pturmel, for you input and advice.
I'll will be looking at the link over the weekend.
Woolie
