Put a dictionary onto a root container as a custom property?
I have a popup window that can be called from multiple other windows.
Depending on which main window calls the popup I want to determine the UI update when the user is done creating/updating the record.
I already have a generic way to update the UI for the current user using a list of dictionaries (which have sub dictionaries which makes this a little ill-suited for a dataset).
Therefore I think the easiest way for me to do this would be to put the UI Update data as a custom property on the root container of the window which will then get fed to my generic message handler that updates the UI.
I am in script console and I thought .putClientProperty was the way to go but this
win = system.gui.getWindow("Pop_AddEditUser")
rc = win.getRootContainer()
rc.putClientProperty("updateAfter",{"something":1})
for prop in rc.properties:
	if prop == 'updateAfter':
		print prop
for thing in dir(rc):
	if thing == 'updateAfter':
		print thing
rc.updateAfter
shows me nothing, I can’t seem to access, and the last line gives me an attribute error.
Is there a way to do this?
I’m not positive, but a client property isn’t the same thing as a custom property, so wouldn’t the last line be this?
rc.getClientProperty('updateAfter')
Ahh, I should have realized to use a getter after using a setter. That works, thank you!
You are correct. .getClientProperty() is the only way to retrieve them.
