Python dataset group by date
Hi
In perspective I get dataset from MySQL db and put it in charts and tables in object format.
To avoid to get another SQL query, I would like to group by day, month, year my dataset variable with a script transform.
Is it possible in python ?
Thanks,
The Simulation Aids Module might help. You can use psuedoSQL on a dataset with its view() function.
Thanks,
Do you have an example with a group by statement ?
Mydataset :
[{'t_stamp':'2021-01-01 00:00:00','value':59}, {'t_stamp':'2021-01-01 01:00:00','value':52}, ...]
SQL query in view() :
SELECT DATE(t_stamp) as t_stamp, sum(value) as value GROUP BY DATE(t_stamp)
I tried expression but it doesn’t work :
view('select date(t_stamp),sum(value) as value group by date(t_stamp)',{this.props.dataSources.example})
There’s no date() function. Just use the t_stamp column if it already has zeros for hour, minute, second.
view('select t_stamp,sum(value) as value group by t_stamp',{this.props.dataSources.example})
It still not working. I think SimulAids Module can’t responds to my needs ==> just group a dataset by day
Your ‘dataset’ looks like a list of dictionaries. view() needs an actual Dataset.
It seems pandas library can group data but it can’t be installed in ignition. Is it true ?
Yes, you can not use any python library which has ‘C python’ dependencies.
Is there any other solution to aggregate data (grouping like sql) with python ?:sob:
Just get the data in dataset format in some custom property. Transform it to object format where you are currently using it, and use the dataset for the view() operation.
I had the same question, my topic might be able to help you!
https://forum.inductiveautomation.com/t/replace-row-values-in-a-dataset/67987
