File “event:actionPerformed”, line 10, in
IOError: (2, ‘No such file or directory’, ‘\\BRPAAPP001\zebra\bufferclearlable.txt’)
Its s Zebra Printer, so they are a bunch of ZPL commands to clear the buffer and then print a label indicating that the buffer is clear…
Thanks Jordan, I have tested manual transfers… I can do the transfer fine from my laptop in python and it works just fine, unfortunately when I move it to Ignition is where I start getting the errors.
Be aware that you are using Jython and not CPython in Ignition. You are trying to open a file from a network path. Java and windows network paths doesn’t work in a easy way.
Before doing the FTP thing, be sure that you can reach that file from network location.
