I am trying to import “pycrypto 2.6.1” library in ignition, for that i have pasted the directory named "Crypto"in to “C:\Program Files\Inductive Automation\Ignition\user-lib\pylib” directory.
I want to use various functions which are in AES module, located at “Crypto/Cipher”.
In script i am importing the module as—>>
from Crypto.Cipher import AES
container = AES.new('key', AES.MODE_CBC, 'IV')
Hi, roshanbhosale
Have you solved your promble, I also want to use AES module in Crypto/Cipher library, but didn’t succed, can you share your resources for me?
You cannot use python libraries that use C .dll or .so files. Jython is java, not C. Consider using Java’s built-in crypto libraries, which jython can use.
