Python @property and @setterName.setter
I am writing a python class and wish to use getters and setters. I am unsure why this is failing with the object has no attribute ‘setter’. Was this not implemented in Jython?
Ignition platform is trial V 7.8.3
Class code
Test Class
class Test(object):
‘Common base class for all test objects’
# Hidden variable
__iCount = 0
# Instantiate the class.
def init(self):
self.__iCount += 1
def del(self):
print class_name, “destroyed”
# Class Methods.
def count(self):
	return self.__iCount
@property
def myProp(self):
	return self.__x
@myProp.setter
def myProp(self, value):
	self.__x = value
calling code
test = project.hosey.classes.Test()
test.myProp(12)
print test.myProp()
ERROR [ActionAdapter-AWT-EventQueue-2] Error executing script for event: actionPerformed
on component: Button 1.
File “event:actionPerformed”, line 1, in
ImportError: Error loading module classes: ‘property’ object has no attribute ‘setter’
</Console error output>
I don’t think the property getter/setter/deleter decorators were available in Python 2.5.
Those decorators are available in Jython 2.6: docs.python.org/2/whatsnew/2.6. … ge-changes.
You can see the plan to upgrade Jython 2.5 to Jython 2.7 in Ignition here: ideas.inductiveautomation.com/fo … jython-2-7
Instead of using the property decorator you can use the builtin property function. See here: docs.python.org/2/library/funct … l#property
Best,
Thank you. I have decided to use this as a work around.
So far it appears to do exactly what I am expecting it to do.
# Test Class
class Test(object):
	'Common base class for all test objects'
	# Hidden variable
	__iCount = 0
	def __init__(self):
		self.__iCount += 1
	def __del__(self):
		print class_name, "destroyed"
	# Class Methods.
	def count(self):
	def myProp(self, value = None):
		if value is not None:
			self.__x = value
			print "setter called"
		print "Method called"
		return self.__x
I’m trying to use the property function as follows:
class State:
	def __init__(self, value):
		print 'init'
		self._x = value
	def getValue(self):
		print 'get'
		return self._x
	def setValue(self, value):
		print 'set'
		self._x = value + 1
	x = property(getValue, setValue)
state = State(1)
print state.x
state.x = 5
print state.x
when I run the code I get the following output:
init
get
1
5
when I assign a value to state.x shouldn’t the setter function setValue be called? because it clearly isn’t. Otherwise the output should have some lines with:
 set
and the values printed should be 2 and 6. No?
I’m using 7.9.3 on JRE 1.8.0_141
Never mind… I figured out why. My class definition was not inheriting the object class.
class State(object):
Now it’s working fine.[quote=“thosey, post:1, topic:12278”]
[/quote]
If you define your getters and setters this way you should be fine.
