We try to use the requests library in Ignition (8.1.15).
We get this error:
Error running action 'component.onActionPerformed' on jasperlg@D/root/Button: Traceback (most recent call last): File "<function:runAction>", line 2, in runAction ImportError: Error loading module requests: Traceback (most recent call last): File "<module:requests>", line 86, in <module> File "<module:requests>", line 72, in getImage File "<module:requests>", line 48, in create_signed_jwt File "/usr/local/bin/ignition/user-lib/pylib/site-packages/jwt/api_jwt.py", line 64, in encode return super(PyJWT, self).encode( File "/usr/local/bin/ignition/user-lib/pylib/site-packages/jwt/api_jws.py", line 118, in encode raise NotImplementedError( NotImplementedError: Algorithm 'RS256' could not be found. Do you have cryptography installed?
We used pip for Jython, so we could import the library with all it’s dependencies, but it still asked for the cryptogrpahy library.
I tried installing cryptography, but pip on jython refused to install it and gives this error:
ERROR: Command errored out with exit status 1:
command: /usr/local/jython/bin/jython /usr/local/jython/Lib/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-mmTpXJ/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (34 lines):
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.python.core.io.StreamIO (file:/usr/local/jython/jython.jar) to field java.io.FilterInputStream.in
WARNING: Please consider reporting this to the maintainers of org.python.core.io.StreamIO
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
DEPRECATION: pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Collecting setuptools>=40.6.0
Using cached setuptools-44.1.1-py2.py3-none-any.whl (583 kB)
Collecting wheel
Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.0.tar.gz (484 kB)
command: /usr/local/jython/bin/jython -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-jXS2Lc/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-jXS2Lc/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-8Qff1t
cwd: /tmp/pip-install-jXS2Lc/cffi/
Complete output (15 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-jXS2Lc/cffi/setup.py", line 148, in <module>
ask_supports_thread()
File "/tmp/pip-install-jXS2Lc/cffi/setup.py", line 76, in ask_supports_thread
ok = (sys.platform != 'win32' and
File "/usr/local/jython/Lib/distutils/command/config.py", line 232, in try_compile
self._compile(body, headers, include_dirs, lang)
File "/usr/local/jython/Lib/distutils/command/config.py", line 136, in _compile
(obj,) = self.compiler.object_filenames([src])
File "/usr/local/jython/Lib/distutils/ccompiler.py", line 821, in object_filenames
if ext not in self.src_extensions:
TypeError: 'NoneType' object is not iterable
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Command errored out with exit status 1: /usr/local/jython/bin/jython /usr/local/jython/Lib/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-mmTpXJ/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
Could it be that cryptography is CPython only? Or how come this can’t be installed? I had the same issue with the Pillow library.
I also tried downloading the libraries manually (for Py2.7), but that gave an error in Ignition.
I’m having a hard time debugging stuff like this.
Any help here would be great.
