Python script to call all emails in a User Role
Hi, I'm looking for a way to pull a list of all user emails in a User Source & Specific Role. This list would be passed into system.net.sendEmail "to" field. Is there a way to do this?
I started looking down system.user.xxxx functions but I don't see anything to pull users in a specific role.
system.net.sendEmail - Ignition User Manual 8.1
I currently have User Source and Roles working inside Report Scheduling. Also am using the latest version of Ignition 8.1 on this Gateway.
Thanks!
Could use the below as a starting point
result = system.user.getUsers('default')
for user in result:
	contact = user.getContactInfo()
	role = user.getRoles()
	print contact
	print role
role will output a list of strings containing all of the roles
contact will be the contact information object
You'll just need an if statement to check for if the roles contains your specific role
More information from here:
https://docs.inductiveautomation.com/display/DOC81/system.user.getUsers
Thanks for the comment! I was hoping there was a method or function somewhere with the roles already nested, but your method will work fine to parse it out.
Ended up building a little function to handle the request + more that I think will get me what I need:
# Returns a list of contact info for Users in Source and Role
# ContactType = 'sms', 'phone', 'email', etc.
def retrieveContactList(UserSource, UserRole=None, ContactType="email"):
	userList = []
	ourContactList = []
	userList = system.user.getUsers(UserSource)
	for user in userList:
		if UserRole != None:
			# Look for UserRole
			if UserRole in role:
				try:
					newContact = None
					for i in range(len(contact)):
						theString = str(contact[i])
						index = theString.find(ContactType)
						if index != -1:
							newContact = theString
							break
					if newContact != None:
						parsedContact = newContact.replace(ContactType+": ", "")
						ourContactList.append(parsedContact)
				except:
					None
		else:
			# No User Role
			try:
				newContact = None
					if index != -1:
						break
			except:
				None
	return ourContactList
Sorry, I couldn't help myself. That function is crying out for a reduction. This may be too svelte, but, an exact duplicate of functionality in 3 lines (technically, one expression!):
	return [
		ci.value
		for user in system.user.getUsers(UserSource) if (UserRole is None or UserRole in user.roles)
		for ci in user.contactInfo if ci.contactType == ContactType
And undoubtedly 2-3 times more performant, too.
I may or may not have posted to get some much needed assistance on my coding :sweat_smile:
Thanks!
Damn, you posted this while I was writing one too !
Damn kids made me lose the race !
def list_contacts(source, user_role=None, contact_type='email'):
	users = [u for u in system.user.getUsers(source) if user_role in u.roles or user_role is None]
	return [ci.value for u in users for ci in u.contactInfo if ci.contactType == contact_type]
Not bad - looks like your estimate was right on the money :slight_smile:
Comprehension avg: 9105.24934935 ns
Imperative avg: 23457.4636637 ns
Pascal's comprehension avg: 9966.44314314 ns
Summary
def retrieveContactList(users, UserRole=None, ContactType="email"):
	return [
		ci.value
		for user in users if (UserRole is None or UserRole in user.roles)
def retrieveContactList2(userList, UserRole=None, ContactType="email"):
	ourContactList = []
			# Look for UserRole
				try:
					newContact = None
						if index != -1:
							break
				except:
					None
		else:
			# No User Role
			try:
				newContact = None
					if index != -1:
						break
			except:
				None
def list_contacts(user_list, user_role=None, contact_type='email'):
	users = [u for u in user_list if user_role in u.roles or user_role is None]
from java.lang import System
from functools import partial
def timeIt(fn, loops=10000):
	def timer():
		mark = System.nanoTime()
		fn()
		elapsed = System.nanoTime() - mark
		return elapsed
	# pop off the last 10 events since they're probably artificially high (GC spikes)
	toAverage = sorted(float(timer()) for _ in xrange(loops))[:-10]
	return sum(toAverage) / len(toAverage)
users = system.user.getUsers("default")
print "Comprehension avg:", timeIt(partial(retrieveContactList, users)), "ns"
print "Imperative avg:", timeIt(partial(retrieveContactList2, users)), "ns"
print "Pascal's comprehension avg:", timeIt(partial(list_contacts, users)), "ns"
The comprehension I posted slightly edges out Pascal's, probably because of the extra list allocation intermediary, but it's such a slight difference that the simpler syntax might be easier to maintain. Subjective choices abound in programming.
Note: All of these tests are on an extremely small user source. The performance difference between these options is going to grow linearly with the input size, and the doubly nested comprehension will continue to behave better and better.
Frankly I find yours simpler. Maybe it's because of how it's split into several lines.
I'd probably do it this way too, for me... But I thought separating users and addresses might make things simpler to understand.
I spent a lot of time refactoring my poorly written code into less poorly written code, so I've developed an eye for these things. :wink:
Okay, I've definitely spent way too much time on this now, but it's interesting, dammit.
A 'more fair' imperative translation of the nested comprehensions is much closer to the same performance (the majority of the difference before was slow string indexing/replacement operations); in fact, it's sometimes slightly faster:
For 100 users
    Comprehension
    mean 207955.52ns
    stdDev 10582.36ns
    Imperative
    mean 213307.58ns
    stdDev 9908.74ns
    Pascal
    mean 241134.32ns
    stdDev 7834.83ns
  Filtering by role
    Comprehension
    mean 132700.64ns
    stdDev 3535.45ns
    Imperative
    mean 114241.66ns
    stdDev 22767.67ns
    Pascal
    mean 134536.15ns
    stdDev 2964.58ns
For 1000 users
    Comprehension
    mean 2068981.27ns
    stdDev 54455.94ns
    Imperative
    mean 2137922.57ns
    stdDev 95904.05ns
    Pascal
    mean 2509863.96ns
    stdDev 211672.25ns
  Filtering by role
    Comprehension
    mean 1048834.59ns
    stdDev 82326.93ns
    Imperative
    mean 1058578.15ns
    stdDev 94194.53ns
    Pascal
    mean 1094843.70ns
    stdDev 92648.91ns
For 10000 users
    Comprehension
    mean 21904184.91ns
    stdDev 2662372.10ns
    Imperative
    mean 19787442.22ns
    stdDev 644613.36ns
    Pascal
    mean 22563649.73ns
    stdDev 749047.54ns
  Filtering by role
    Comprehension
    mean 9131573.53ns
    stdDev 425773.98ns
    Imperative
    mean 9057692.98ns
    stdDev 399956.14ns
    Pascal
    mean 8859192.44ns
    stdDev 158626.05ns
Summary
	return [
		ci.value
	ourContactList = []
		if UserRole is None or UserRole in user.roles:
			for contactInfo in user.contactInfo:
				if contactInfo.contactType == ContactType:
					ourContactList.append(contactInfo.value)
import random
from com.inductiveautomation.ignition.common.user import ContactInfo
def tukeys_fences_filter(data, k=1.5):
    # Calculate quartiles
    data.sort()
    n = len(data)
    q1_index = int(n * 0.25)
    q3_index = int(n * 0.75)
    q1 = data[q1_index]
    q3 = data[q3_index]
    # Calculate interquartile range (IQR)
    iqr = q3 - q1
    # Calculate fences
    lower_fence = q1 - k * iqr
    upper_fence = q3 + k * iqr
#    print data[0], lower_fence, upper_fence, data[-1]
    # Filter data within the fences
    return [x for x in data if lower_fence <= x <= upper_fence]
def timeIt(name, fn, loops=1000):
	def timer():
		fn()
		return System.nanoTime() - mark
	toAverage = tukeys_fences_filter([float(timer()) for _ in xrange(loops)])
	print '\t', name
	print '\tmean {:.2f}ns'.format(system.math.mean(toAverage))
	print '\tstdDev {:.2f}ns'.format(system.math.standardDeviation(toAverage))
class FakeUser(object):
	possible_roles = ["Administrator", "Operator", "Supervisor", "Technician"]
	possible_contact_infos = ["email", "sms", "phone"]
	def __init__(self):
		self.roles = [self.create_role() for _ in xrange(random.randrange(len(self.possible_roles)))]
		self.contactInfo = [self.create_contact_info() for _ in xrange(random.randrange(5))]
	def create_role(self):
		return random.choice(self.possible_roles)
	def create_contact_info(self):
		return ContactInfo(
			random.choice(self.possible_contact_infos),
			''.join(random.sample("abcdefghijklmnopqrstuvwxyz", 20))
for n in [100, 1000, 10000]:
	users = [FakeUser() for _ in xrange(n)]
	print 'For', n, 'users'
	timeIt("Comprehension", partial(retrieveContactList, users))
	timeIt("Imperative", partial(retrieveContactList2, users))
	timeIt("Pascal", partial(list_contacts, users))
	print '    Filtering by role'
	timeIt("Comprehension", partial(retrieveContactList, users, "Operator"))
	timeIt("Imperative", partial(retrieveContactList2, users, "Operator"))
	timeIt("Pascal", partial(list_contacts, users, "Operator"))
	print
	print
I reserve the right to have done something fundamentally wrong somewhere :slight_smile: Either way, maybe someone will find some of the code in there reusable for something else.
Wow the imperative did way better than I thought, especially once you get to 1000 users it beats out both your comprehension and Pascal's, that right?
Comprehension
mean 21904184.91ns
stdDev 2662372.10ns
Imperative
mean 19787442.22ns
stdDev 644613.36ns
Pascal
mean 22563649.73ns
stdDev 749047.54ns
Pretty surprising! I guess the boost from comprehensions/ding for using imperative style is smaller than I thought, at least for this specific case.
