I’m wanting to parse the first 4 character from the string.
I’m getting this error when I run the following code:
Code:
scanEntry = event.source.parent.getComponent('txtJobNum').text
entry = scanEntry.split[:4]
event.source.parent.getComponent('t1').text = entry
Error:
[code]Traceback (most recent call last):
File “event:actionPerformed”, line 2, in
TypeError: ‘builtin_function_or_method’ object is unsubscriptable
at org.python.core.Py.TypeError(Py.java:235)
at org.python.core.PyObject.__finditem__(PyObject.java:585)
at org.python.core.PyObject.__getitem__(PyObject.java:653)
at org.python.core.PyObject.__getslice__(PyObject.java:740)
at org.python.pycode._pyx25.f$0(<event:actionPerformed>:3)
at org.python.pycode._pyx25.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:623)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy33.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Ignition v7.8.2 (b2016030813)
Java: Oracle Corporation 1.8.0_60
[/code]
