Qualified Value in Change Script Perspective
Hi everyone,
I’m writing to you because I have a problem with a qualified value from a change script for the “items” property of a tree in perspective.
There is 2 arguments natively implemented in the script, which are “currentValue” and “previousValue”, but when I try to access currentValue.value elements it throws me an error saying that there is no such arguments for this data.
Here is what the currentValue.value looks like :
Here is the code :
code
But Then it just throws at me this error :
I have tried currentValue[0].value, test[0].items(), test.items(), no success.
Also it’s the same the other element of items (data, label, …)
Thank you !
can you show us what it returns and if any of them work?
dict(test), dict(test[0]), dict(currentValue) and dict(test['items'])
I see this as text, not test.
Thank you for you answer.
Nonce of your suggestion works, here is the screenshots : :
dict(test[0]) :
dict(currentValue) :
dict(test):
dict(test[‘items’]) neither
Thank you for you answer. Yeah this is normal, because i’m using a label component just to see the dada, so im displaying the data in the text property of the label
TypeError: cannot convert dictionary update sequence element #0 to a sequence
ah this is interesting it means its an array not a dict
can you assign test to a custom key for a second and show us what it gives?
like create a custom component (key) and do self.custom.key = test
I created a custom property (called “test”) for the label component and assigned test to it, here is what i get :
custom key
alright then test[0].items should be an array of the items
(ofc no need to use the custom key in between)
Ok it works, looks like I can’t use directly “currentvalue.value”, I need to pass it to another custom property then use this property to do what I want. Don’t know why but anyway I will use that, thank you for your help !
Oh it doesnt work without the custom?
Then it might be that its a json string
So I would need to decode the json before using it ?
Its worth a try xd
Ok thank you, I will try that and I would post the code here if I managed to do so !
something like?
test = curval...
test = system.util.jsonDecode(test)
self.get ...
do anything
Ok I tried that, but here is what I get :
error string
Hm wierd xd
what gives
type(test)
This is what I get : class org.python.core.PyArray
huh then i dont see why that didnt work before...
maybe test[0] is the json?
what does type(test[0]) give?
Here is the type of test[0] : class com.inductiveautomation.perspective.common.ImmutableQualifiedValue
and the type of test[0].value is class java.util.HashMap
oh weird, then this might work:
test[0].value.items
test[0].getValue().items
or if that doesnt:
system.util.jsonDecode(test[0].toString()).items
surely should do something xd
