Quarantine data
Hi Guys. I have trouble to add new tags to the table sqlth_te table after I inserted some extra tables into the existing schema, and I’m sure these added tables have nothing to do with ignition tag historian module generated tables.
I found these in diagnostic log
java.sql.SQLException: Field 'id' doesn't have a default value
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:129)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeInternal(ClientPreparedStatement.java:953)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeUpdateInternal(ClientPreparedStatement.java:1092)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeUpdateInternal(ClientPreparedStatement.java:1040)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeLargeUpdate(ClientPreparedStatement.java:1347)
at com.mysql.cj.jdbc.ClientPreparedStatement.executeUpdate(ClientPreparedStatement.java:1025)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:1016)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepInsertGetKey(SRConnectionWrapper.java:262)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.getTagIds(TagHistoryDatasourceSink.java:794)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.insertTagValues(TagHistoryDatasourceSink.java:896)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeScanClassSet(TagHistoryDatasourceSink.java:482)
at com.inductiveautomation.gateway.tags.history.storage.TagHistoryDatasourceSink.storeDataToDatasource(TagHistoryDatasourceSink.java:459)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.lambda$storeToDatasource$1(AbstractDatasourceSink.java:139)
at com.inductiveautomation.ignition.common.functional.FragileConsumer.lambda$wrap$1(FragileConsumer.java:45)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.stream.Streams$StreamBuilderImpl.forEachRemaining(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeToDatasource(AbstractDatasourceSink.java:138)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AbstractDatasourceSink.storeData(AbstractDatasourceSink.java:117)
at com.inductiveautomation.ignition.gateway.history.sf.sinks.AggregateSink.storeData(AggregateSink.java:180)
quarantine.xml (47.2 KB)
Can you check the sqlth_te table's structure? id definitely should be marked as an auto-increment/not null/primary key/etc in whatever database you're using, so this is odd.
super! the “auto increment” was mistakenly unchecked by someone. thank you very much!
