Queries/sec by client
Good morning,
I would like to ask you if there is any way to know the QueriesPerSec divided by client. Now I’m just displaying the total I read from the variable System > Gateway > Database.
Thank you for the help!
You can check the QueriesPerSec for each client instance from the Diagnostics window of an active client.
This page of the manual refers to the Designer clients, but the options apply the same to Vision clients.
You can also trigger the diagnostics window to open using system.gui.openDiagnostics if you have Hide Menu Bar selected in Project Properties > Vision: User Interface.
Thank you stat for your reply, this will be very helpful.
Just to understand, in the way you told me I should connect to every client to check it, but I wonder if there is a way (a script or something else) to show for example in a table all the client with their performance.
At the moment I have always 20-25 client connected and check one by one is almost impossible (some client I have a direct access, others I haven’t).
Thanks again and have a nice day.
Sorry if I ask again, any new help?
Thank you very much.
