Query binding to piechart
Hello good morning to all,
I am having a problem with displaying the data of my query in the pie chart, I am passing the information I think properly but when I go to the screen I get "data invalid".
Thank you very much for your help, I attach a couple of screenshots that I hope will facilitate the understanding of the problem.
Query
data invalid
script
What do the logs say ? Can you show us the piechart config ?
Also, let's 'fix' that script transform:
for i in range(value.getRowCount()):
    labelList.append(str(system.dataset.toPyDataSet(value)[i][0]))
ew !
You're converting the same dataset to a pydataset once per row !
You could use dataset.getValueAt() instead:
    labelList.append(value.getValueAt(i, 0))
Or first convert to a pydataset, then loop through it:
ds = system.dataset.toPyDataSet(value)
for row in ds:
    labelList.append(row[0])
But there's actually a better, built-in way to do this:
labelList = value.getColumnAsList(0)
Your piechart doesn't work because your first label don't have a value in it:
Your query result shows the same issue:
Thanks!!!!
