Hi guys,
I’m trying to get the contents in a certain column referring to the name of the row in a table. My code is following:
Target_Column_SQL = "[.]Station_ID"
Name = "[.]Name"
Trainer = "[.]Trainner_Log_In"
Level = "[.]Training_Level"
sourceTagPath = "[.]Badge"
database = 'DW_SCADA_MSSQL'
badgeRead = system.tag.readBlocking([sourceTagPath])[0].value
target = system.tag.readBlocking([Target_Column_SQL])[0].value
ReadResult = []
if currentValue.value != "0":
query = "SELECT Badge, employee_name, [{0}]] FROM Training_Matrix WHERE Badge = ?".format(target)
ReadResult = system.db.runPrepQuery(query, [badgeRead], database)
if ReadResult:
system.tag.writeBlocking([Name], [ReadResult[0][1]])
system.tag.writeBlocking([Level], [ReadResult[0][2]])
if ReadResult[0][1] in ('Khuc, Hoa The', 'Osorno, Hector', 'Imafidon-Taiwo, Shogbolu', 'Janapareddy, Sreedhar'):
system.tag.writeBlocking([Trainer], [True])
else:
system.tag.writeBlocking([Name], ["User Not Found"])
system.tag.writeBlocking([Level], [""])
The script attached to a child tag to my UDT as following:
For some reason the script would not work as I expected.
But when I remove the dynamic element [{0}] and .format(target) then replace with solid name “WL_OP10_30“ in the following code, the script works.
query = "SELECT Badge, employee_name, WL_OP10_30 FROM Training_Matrix WHERE Badge = ?"
Can anyone give me some clue?
**Sorry for the confusing if the layout doesn't make sense.
