Query help sql date range between grouping 7am to 7am
At some point you are going to be asked to collect and summarize by rotating shifts with arbitrary rotation patterns. It can get complicated. The following generic solution may help you create the correct joins against your production records:
You'll have to tweak it for use with SQL Server.
