I am having periodic issues running a query in my Ignition script. I have a select statement and I am inserting the rows returned. Example below
INSERT INTO *my_table* ()
SELECT columns FROM *a_different_table*
Most of the time the query runs without issue but sometimes when it runs, I get an error and see this in the log A result set was generated for update.
I have also tried using SET NOCOUNT ON in my query but I get the same error.
I am using this command to run the query system.db.runPrepInsert() but recently changed it to system.db.runPrepUpdate(). But I am not confident that it will work so I'd like to ask if maybe someone has a different solution that I haven't tried.
Thanks for your help!
