Query reporting improperly
My query is skipping days of logging days. its skipping a week and at times 2 weeks in row. Anyone see the issue with my script? My transaction group has all the correct data.
SELECT  Diesel,  TranSynd_ATF , [75_90_WT_SYN], [75_90_WT_SYN_2], [50_WT_MTF] , [10W_30] ,  Diesel_2 ,  MD3_ATF , Coolant ,  DEF ,  t_stamp
From TankFarm
Where DATEPART(DAY, t_stamp) >= DAY(getDate()-7) OR DATEPART(DAY, t_stamp) = DAY(getDate())
Order by t_stamp desc
How's that supposed to work at month end roll-over? e.g., on 2024-08-06 you'll have,
                          ^^^ -> 30 (returns only 30th + 31st)
OR
                         ^^^ -> 6
General comments:
  1. Your query has to scan the data table and run every row's t_stamp through the DATEPART function before it can do the comparison. If the t_stamp column is indexed it's no use for this query. You should be selecting by t_stamp > .... This way the query only examines records within the date range.
  2. OR DATEPART(DAY, t_stamp) = DAY(getDate()) seems redundant. Today is always > seven days ago (ignoring the problem addressed in comment 1).
@Transistor Ohhhh you're right. I'm only getting dates of the 6th,30th, and 31st.
Good! Now show us your modified query that uses the t_stamp index properly!
@Transistor
From TankFarm
Where t_stamp >= (SELECT MIN(t_stamp) FROM TankFarm)
AND t_stamp <= GETDATE()
That should perform a lot better.
Unless your database has records from the future, the line
is redundant.
Tips:
  • Decide on whether SQL keywords are uppercase or lowercase and then be consistent.
  • You can wrap lines for readability.
SELECT
  Diesel,
  TranSynd_ATF ,
  [75_90_WT_SYN],
  [75_90_WT_SYN_2],
  [50_WT_MTF] ,
  [10W_30] ,
  Diesel_2 ,
  MD3_ATF ,
  Coolant ,
  DEF ,
  t_stamp
FROM TankFarm
WHERE t_stamp >= (SELECT MIN(t_stamp) FROM TankFarm)
ORDER BY t_stamp DESC
It's easier to find fields, count them and reorder them.
Ok I removed that line. Still shows the same data as before. Thanks.
I just took over our Ignition so been cleaning up stuff. Still have alot to learn so thanks for any tips and input.
Don't use column names that start with digits. There are a number of places in Ignition that will barf at that.
I was thinking the same thing but thought I had enough in my post. Don't forget that you can rename the columns in the query.
SELECT
  Diesel,
  TranSynd_ATF ,
  [75_90_WT_SYN]   AS wt_syn_75_90,
  [75_90_WT_SYN_2] AS wt_syn_2_75_90,
  [50_WT_MTF]      AS wt_mtf_60,
  [10W_30]         AS somethingElseMeaningful,
