Hi All!
I am attempting to use a scalarPrepQuery with one argument in the where clause:
PN = str(system.tag.readBlocking(["[default]CurrentPartNumber"])[0].value)
query_lower = “”“SELECT TOP (1)
[LOWER_SPEC]
FROM [Test].[dbo].[GET_SPEC]
WHERE EQUIP_NUM = ‘XXX’ AND PART_NUMBER = ?
ORDER BY TIMESTAMP DESC”""
lowerSpec = system.db.runScalarPrepQuery(query_lower,[PN])
And it returns no results.
The weird thing is, if I instead type the returned tag value into the PN variable like this:
PN = ‘PartNumber’
And then run it, it returns the results I’m looking for.
Has anyone else seen this? I checked the type and both show as strings and if you print them out (the tag value and the manually typed in one) they both look identical
Try this
PN = system.tag.readBlocking(["[default]CurrentPartNumber"])[0].value
query_lower = '''SELECT TOP (1)
[LOWER_SPEC]
WHERE EQUIP_NUM = "XXX" AND PART_NUMBER = "?"
I get an index 1 is out of range exception?
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: The index 1 is out of range.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:359)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:333)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:286)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:868)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:839)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runPrepQuery(ClientDBUtilities.java:317)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runScalarPrepQuery(AbstractDBUtilities.java:308)
... 23 more
hmm…try this. If this doesn’t work, isolate the PN= line and add print PN to make sure the value you are getting is what you expect
[LOWER_SPEC]
WHERE EQUIP_NUM = "XXX" AND PART_NUMBER = ?
print PN
I’d recommend print repr(PN) so you can see any white spaces or hidden characters.
WillMT10 gets the prize! I didn’t know about repr and print wasn’t showing anything.
Thank you!
I’m getting this:
“u’PartNumber\r\x00’”
Is there an ideal way to get rid this? Just use spring parsing to delete the first and last ones? Or is there a more elegant way to drop hidden characters?
Okay I did a google and came up with this:
PN = re.sub("[^a-z0-9]+","", PN, flags=re.IGNORECASE)
Figured I’d ask if this is how y’all do it or if there is an ignition library that is better. But either way seems to be working!!
Thank u for the help!
-Kelly
If the format is always the same (with a CR after the part number), you can use split():
s = u'PartNumber\r\x00'
print repr(s)
t = s.split('\r')
print t
print repr(t[0])
Output:
u'PartNumber\r\x00'
[u'PartNumber', u'\x00']
u'PartNumber'
