Query Tag Binding Question
Good afternoon Team,
One final question today.
I have created a query tag that I bound to the ‘selected’ value on my toggle switch. The tag value from the db is Boolean. I need it to be Enabled or Disabled. I tried to use a transform on the 1,0 value from the tag binding but it only shows null. I then tried to do a mapping on the toggle switch text thinking I could map the 1,0 to Enabled or Disabled.
It did not work. Any ideas as to why?
Your tag value is a string (Note the selected value is green. Also, hovering over the little error triangle will give you hints).
I would normally recommend ending up with a boolean type for your tag, but if it’s not possible, then add a map to the selected property:
The map for the label text then becomes:
Thanks again Jordan, I thought that it might be a value issue but was not sure how to change it to string.
