Query Tag History: Retrieve Only Timestamps
Hello,
I am using system.tag.queryTagHistory() and I have stored large JSON/FFT string data in tag history. When I query these tags over a long time range, the query becomes very slow because of the large string values.
What I really need at first is only the t_stamp column, so that I can later fetch the actual data on demand when the user selects a timestamp.
Is there a way to query only the t_stamp values from history (without pulling the string column), or is there a recommended approach for handling this use case?
If anyone has a solution or workaround, please share.
Thanks in advance ! :slightly_smiling_face:
Hm for this specific use case, I would rather use a custom SQL table to hold the data instead of the built-in tag historian…
I’m honestly not sure there is a way to get only the timestamps.
