queryHistory usage
I try to query History from gateway scope with :
context.getTagManager().queryHistory(tagHistoryQueryParams, streamingDatasetWriter);
tagHistoryQueryParams.setPaths(); is used to provide tagPaths.
In the BasicTagPath, do we need to provide the history provider in the source ?
In this case what is the form/synthax to use ?
Probably the tag provider is enough, the history provider is resolved with it.
@paul-griffith
I try to create a BasicTagHistoryQueryParams, but I’m looking for an example for those settings :
tagHistoryQueryParams.setAggregationMode();
tagHistoryQueryParams.setAliases();
tagHistoryQueryParams.setColumnAggregationModes();
tagHistoryQueryParams.setEndDate()
tagHistoryQueryParams.setStartDate();
tagHistoryQueryParams.setQueryFlags();
tagHistoryQueryParams.setReturnFormat();
tagHistoryQueryParams.setReturnSize();
With only the following :
(startDate => now + 1 days
endDate => now - 2 days)
tagHistoryQueryParams.setEndDate(startDate);
tagHistoryQueryParams.setStartDate(endDate);
tagHistoryQueryParams.setReturnFormat(ReturnFormat.Tall);
Flags flags = Flags.createFromValue(TagHistoryQueryFlags.BOUNDING_VALUES_YES);
flags.and(TagHistoryQueryFlags.NO_INTERPOLATION);
flags.and(TagHistoryQueryFlags.NO_SCANCLASS_VALIDATION);
return only the last value for the specified tag ???
I need to collect all the raw history values…
streamingDatasetWriter.getRowCount() = 1
histo.sqlt_data_1_2018_12 for the tag contain 3 values :
29	5				192	1544173333405	2018-12-07 10:02:13.4050
29	10				192	1544173335803	2018-12-07 10:02:15.8030
29	50				192	1544194325530	2018-12-07 15:52:05.5300
I found what was wrong
To obtain all tags changes, it is necessary to add :
tagHistoryQueryParams.setReturnSize(-1);
In the script function system.tag.queryHistory, returnsize has a -1 as parameter default value :wink:
