I have a query that works fine in MSSQL, when i put it into a QueryTag using tags or with hard coded values it fails. I didnt see anything in the docs so I was hoping someone could shed some light, thanks!
This fails in a Query Tag
SELECT ur.rollID
FROM upe_rolls AS ur
INNER JOIN upe_lot_numbers AS uln ON uln.lotNumID = ur.lotNumID
WHERE uln.lotNumber = 'LOTTEST3' AND ur.rollNum = 1
SELECT ur.rollID
WHERE uln.lotNumber = '{[.]E1_LotNum_1}' AND ur.rollNum = {[.]E1_RollNum_1}
It said I did not have a default database selected. But… Default was selected and that is what the rest of the app is using, either way. I made the change and its working now, thanks!
That answer is half correct. They’re not in a project, so they don’t share the project’s default. However, it is possible to set a “default” connection if you log into the gateway, and go to SQLTags>Realtime, and edit the provider.
