Hey guys,
I’m trying to set up a few alarms that are only enabled under specific conditions but I’m getting some weird alarm activation times so I’m trying to figure out exactly how this works.
So, for example, say I have an alarm that has a 30 minute alarm delay.
If the enabled setting is on and the alarm goes active and then the enable setting goes off does the alarm clear?
If the alarm was active and then the enabled setting goes off and then comes back on a few minutes later does the alarm activate right away or does it have to go back through the alarm delay time?
If an alarm was active and got sent to an alarm pipeline and then the enabled setting goes off does the alarm drop out of the pipeline, i.e. it is considered a drop out condition.
