Hello,
Recently other people here have started programming in Ignition. These people are used to programming Rockwell PanelView HMI screens.
My question is about where to do the tag mappings. I have gotten into the habit of doing most mappings into root container custom properties usually with indirect tags. They on the other hand are mapping tags directly in the components that are utilizing the tags even if multiple components use the same tag.
I do it my way from having to rearrange things and trying to track down all the tags down in all the components when I first started doing Ignition HMI screens. Which I’d do totally differently now.
They do it their way because that is the way PanelView works.
Which way is preferred and why?
Thank you,
Bill
