I have a question. I need to develop a database system and all that it has (querying, reporting, multi-user and web-based).
I just want to know if I could develop a complex database system using Ignition instead of others technologies like Java, Python, PHP or .NET. Or what I need to consider if I what to do that, some kind of benchmarking test.
Database driven applications is one the primary type of applications that Ignition is used to create. You can make it as simple or as complex as you want.
Performance is fine in multi-user environments. Of course it depends on the circumstances, are you talking about 10 concurrent users or 1000? You can create an application that runs fast or slow, so it depends on how you make it.
Generally Ignition works well in multi-user environments. It is designed for unlimited clients.
Well, We need to develop an ERP System (Enterprise Resource Planning) for administrate data bases with humans resources data, production and something like that. I didn’t know what was the correct name for it, but I know now.
