Question about named query cache management
Hi @KathyApplebaum
In case of a select named query with parameters, I suppose that the cache doesn’t take care of the value of the query parameter ?
Example : named query “select”, param1
if we execute the query with param1 = A and the with param1= B, the named query reset the cached result or keep a cached result for the query with param 1 = A and another cached result for the query with param 2 = B ???
The ‘cache key’ that is used for caching is derived from the resource ID, the arguments, the string body of the query itself, and the database that it executes against.
For the arguments, you mean the query parameters, or the query parameters AND the value of these parameters ?
The values of the arguments.
So in your example that query will be cached twice – once for param1 = A and once for param1= B
Thanks for these clarifications, I’ve just seen the doc is quite detailed about named query behaviour…:blush:
In the doc, I suppose that “Once the lifespan expires, the cache is invalidated” means that for the case of a named query cached twice: with param1 = A and param 1 = B, both cached result are invalidated ?
Each result is invalidated separately. They are treated as totally different things.
