Hi Paul how to make an offline installation on a system with no access to the internet ?
You download an installer, and then you put it on the computer you need to install Ignition on, using whatever means are allowed (e.g. a USB drive, intranet, etc).
Then you run the installer.
There's a full offline license activation flow:
Hi Paul thanks for your fast response but I just gave it a try, and it seems my mail was a little out of context as it was related to a topic in the forum where you should import
from com.inductiveautomation.ignition.common.util import DigestBuilder
/Hans
I think you've lost me and probably others as a line of scripting to do an import is unrelated to doing an offline install.
You'll need to explain more what you're trying to accomplish and what your problem is.
