Question about the Ignition Gateway logs and wrapper
Hello,
I have a Gateway IO that processes hundreds of devices and processes about a million tags. As a result, I have a lot of logs that clog up memory in minutes, especially modbus.
I limit this by disabling logging of unnecessary Level=Off logs in Log Configuration. When I restart the Gateway everything goes back to default settings.
Is it possible to set logging to only those items in Log Configuration that I want to monitor? It seems to me that handling so many logs and wrapper also affects the load on the Gateway system.
Example view from my test gateway:
Regards
Michal
You can make log level changes that persist by editing the data/logback.xml file.
For each logger you can add an entry like this:
<logger name="com.inductiveautomation.fully.qualified.logger.name" level="OFF" />
https://logback.qos.ch/manual/configuration.html#loggerElement
