Hello:
I’ve been working with the Ignition Designer (Ignition version 8.1.12)  for a year now. In regards with the Image Management tool, I’ve noticed that once I upload an image, if I change anything in it (externally, say with inkscape) and I upload it again to be used in your perspective project (with the same filename), it still shows the former image rather than the new one with the modification.
I’ve tried:
- Deleting the image from the perspective view and from the Image Management tool, just to make sure I am starting with a clean slate.
 - Uploading the newly changed image (with the modifications I did in Inkscape)
 - Creating a new image in my perspective view and linking it to the one in the Image Management tool.
Result:
It still loads the old image.
Workaround:
For each change that I make to the original image, I save it and uploaded with a different filename.
Imagev1.svg
Imagev2.svg
and so forth
Please advise
Thanks in advance
