Question - Memory Boolean array Tag
Hello,
I have defined a bool array in the provider I have the following questions.
If I have a huge array, do I need to click this tool to create an array of the needed size? Or is there another way? What if I need to have an array [500]?
Another question is why when I do a double click on a variable its size changes to [1] and what if I make a mistake in the script and write it to the zBooleanArray value and the array shrinks to one. I have to define it again.
Is this normal, why is this happening? Is there a way to define large arrays more conveniently?
Best regards,
Michał
The array sizes aren't static, so you can just create one of any length and then write a new value of the desired size to it like this:
system.tag.writeBlocking(["[default]BoolArray"], [[True]*500])
