Having an issue with a stored procedure call.
Here is the stored procedure in SQL Server
create procedure test.spIAFaultInsert
@station nvarchar(50),
@faultID nvarchar(20),
@faultDescription nvarchar(200)
as
begin
insert into test.IA_Fault (station, faultID, faultDescription)
values (@station, @faultID, @faultDescription);
end
call = system.db.createSProcCall("test.IAFaultInsert", "SqlServer")
call.registerInParam("station", system.db.VARCHAR, "Assy")
call.registerInParam("faultID", system.db.VARCHAR, "F0")
call.registerInParam("faultDescription", system.db.VARCHAR, resultRow)
system.db.execSProcCall(call)
Here is my call I've been working on for a bit this evening. I've just been trying to get it to work on the Script Console. End goal would be to call on tag value change.
Here is the Error Log I'm getting.
Java Traceback:
File "<input>", line 25, in <module>
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:530)
java.lang.Exception: java.lang.Exception: Error executing system.db.execSProcCall()
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:461)
at org.python.core.PyObject.__call__(PyObject.java:465)
at org.python.pycode._pyx72.f$0(<input>:25)
at org.python.pycode._pyx72.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.execSProcCall()
... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: The index 5 is out of range.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:334)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:967)
at com.inductiveautomation.ignition.client.script.ClientDBUtilities._call(ClientDBUtilities.java:356)
at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.execSProcCall(AbstractDBUtilities.java:528)
... 24 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The index 5 is out of range.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:237)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.setterGetParam(SQLServerPreparedStatement.java:1131)
at com.microsoft.sqlserver.jdbc.SQLServerCallableStatement.setObject(SQLServerCallableStatement.java:1596)
at org.apache.commons.dbcp2.DelegatingCallableStatement.setObject(DelegatingCallableStatement.java:1236)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRCallableStatement.setObject(SRConnectionWrapper.java:1607)
at com.inductiveautomation.ignition.gateway.datasource.query.SQLType.setParam(SQLType.java:179)
at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities._callSProc(GatewayDBUtilities.java:313)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.CallSProc.call(CallSProc.java:45)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(null)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:228)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
at java.lang.Thread.run(null)
I'm not really sure where to go as far as what I'm missing to get this to work
