[QUESTION] Some Leased Tags Don't Execute
Some of my leased tags don’t execute once viewed. They have a base rate of 0ms and a Leased/Driven Rate of 2,000ms. If I set this scan mode to Default it will execute which tells me there may be a bug with the leased scan class?
Version: Ignition 8.0.4
Thanks in advance.
Are you testing this in a Vision Client, or in the Designer? Depending on whether or not you have a component binding open in the Designer, you may not see the rate change.
