Questions about Inline frame
Hi everyone, I'm having problems with Inline Frame, I've looked through the forums and haven't found anyone sharing a similar problem to mine.
I put a frontend interface A on Inline Frame, after saving the project and opening it in a browser, it shows the login page for A. After entering my password and clicking login, I can't jump to the homepage of A. I'm having trouble with this.
I checked the developer platform of the browser and the interface to verify the password is triggered successfully after clicking the login button.
What should I do next to troubleshoot the next problem, I have no clue, what I can confirm is that X-Frame-Options is not set to be disabled on A's system.
Maybe there's something wrong with my statement that System A doesn't use X-Frame-Options, so his login page can be displayed normally instead of showing refused to connect. and I do see in the developer tool of my browser that this is not used.
I think it should be something else.
OK. I misunderstood. I'll delete my previous post as it's not relevant.
X-Frame-Options must be affirmatively set to to allow IFrame usage. Missing the option is equivalent to disallowing IFrames, IIRC.
I just added it, but it still doesn't jump from the login page to the home page
"Same Origin" means the IFrame must be delivered by the same server to be allowed. That is the default that prevents other servers from embedding the content in their IFrame.
Sorry I didn't understand carefully, so how do I change this configuration please.
Someone just told me that it's because the token is not being passed, but I don't know if it is, do you understand what it means?
See the docs here:
You need the "Allow-From ..." syntax that explicitly identifies the system that will wrap around the IFrame. But note the compatibility warning that recommends using Content-Security-Policy.
Allow all is the default if nothing is filled in normally.
So that was not what the initial problem was
