I was wondering, I downloaded the PING module and installed it. I can use it in FSQL and I can use it in the FPMI SQLTags section. But I can not seem to get it to work under either the scriting or the expressions sections.
If I use the either of the following command lines in SQL tags or FSQL the commands work fine but anywhere else I get either a syntax error or another error which I dont recall right now.
if(ping((“10.0.0.20”),500),false,true)
if ping((“10.0.0.20”),500:
ALSO in FPMI under SQLTags I can use just:
ping(“10.0.0.20”),500
All of these seem to work under the SQL tags but when I goto put them under in expression or in script they do not. Did I foget to place the DLL files somewhere?
