Questions on setting up gitlab/github?
I’m going off the “Best Practices” PDF for Ignition and am trying to set up Gitlab. The first thing I noticed was that there is no GitLab for windows, which is unfortunate as my application runs on a Windows Server 2012. I also see that GitLab needs 4 gigs of ram to run.
Is is there a document for setting up GitLab on windows for Ignition? It’s unclear to me how I would set this up. I have a Dev server running in a VM and a production server running in another VM, both Windows Server 2012 OS.
You could try a Linux VM, or installing Docker for Windows; there’s an official Gitlab Docker image: https://hub.docker.com/r/gitlab/gitlab-ce.
Do you actually specific need Gitlab? There’s lots of web frontends available for git, including totally free options with better cross platform support: https://gitea.io/en-us/
I don’t really care that it is gitlab specifically.
All I really care about is that I could use git to watch for changes that I can track, etc, and then push to my production repo when I am done developing them. gitea seems like it might be the way to go.
I mean, if you just need to push changes to another repository, you don’t even actually need a web frontend; git can do that directly:
https://git-scm.com/docs/git-push#URLS
https://git-scm.com/docs/git-push#REMOTES
Yup. I use no web front-end at all. I have a 'git' user on one of my office linux VMs, with SSH keys from each employee (all two of us). The push/fetch/pull URLs are then git@myserver.example.com:reponame.
I don’t suppose there’s any plans for an Inductive Univeristy video on this. I’m still kind of confused. I’m used to using Github, pulling from the master, making a branch, making a push request, getting it code reviewed and then it gets accepted into the master branch.
Now I have a VM for my development server that I need pull, make a branch, submit to, and then from there, push those same fully finished changes to my production server which is also being tracked by Git? I don’t get the work flow or the interaction here to be honest.
Pull requests, change requests, etc, that are reviewed in web frontends are not actually part of git itself - they’re a layer above, added by external tools because it’s useful when collaborating. But if all you want to do is keep your local dev environment in sync with some remote environment, you can use git directly to do so - git push can go directly from one computer to another, via SSH or a couple other mechanisms.
If you do need external collaborators/review of your changes, then tools like Github/Gitlab/Gitea are the easiest option; but by no means the only one.
