Hello,
I have two questions regarding objects drawn with the Rectangle Tool:
[ul]Can the stroke style be changed dynamically? I see that you can link it to a tag, but I’m insure of the format of such a tag
Can you assign styles to the rectangle object? I’m creating a template and when I click on the Styles “Dataset Viewer” a warning popup appears that says, “There is no data”.[/ul]
Thanks for your help.
