I inherited a Vision project from engineer that left. He did not build the tag browser one at a time, but imported everything from an xml file. Is there a way to quickly build a csv from a plc export file?
Also, since I can not get to the ignition tags directly to monitor (is there a way) how do i modify existing?
I should add the we use a tag and description when we build the PLC program. tag = EQ_DESC and description is Equipment description
