The User Manual states, and I quote [quote]“Each row in the dataset will become a single series
(polygon) on the chart. The dataset’s first column represents the name of the series, and
subsequent columns represent the values.”[/quote]
However, when I enter a radar chart, it comes with a default dataset that only has 1 series/polygon and the dataset has following columns:
[ul]Column 1 = Value
Column 2 = Min
Column 3 = Max[/ul]
In this case, each row in the dataset actually represents another spoke on the chart. I changed it to a dataset as per the manual, but that simply doesn’t work. ![]()
So: how do I create a radar chart with multiple series ?
Regards
Koen
