Is it possible to change that size of the radio button? I would like to enlarge it and haven’t came across any properties for that.
Casey
Casey
There isn’t a way to change the size of the radio button component, but you can mock it up with the drawing tools to create on/off images to switch between when someone clicks them. Also, Symbol Factory already has on/off symbols that you can use.
